CanYaTakeIt
I live in the USA and bought an unlocked Galaxy s5 from a manufacturer in China. I got an excellent deal on the phone, but a few things are driving me crazy.
1. I cannot change the default pin password lock-screen to anything but default. I have Nova launcher and Widget locker also.
2. In system settings..Lock screen there are only 2 settings to change, S view window color and weather unit.
3.In system settings, Power saving Mode, I only have one option, "@2131495362", and it is a tic box. When tic'ed it does go into power saving mode. I thought there were many options available.
4. When I try system updates it says "You system is currently up to date", but Network connection failed pop up also. I have ATT as my provider.
5. And the biggest annoyance. using Kies 3, I am able to connect to the phone wirelessly, can see the phone when plugged in using usb file explorer, but unable to use Kies 3 to perform any firmware or system changes. Also the csc code in the phone does not have a USA csc code which I would like to update so I can receive the latest updates for my phone.
Gs5 Model # SM-G900H, Android version 4.4.2
If anybody has any tips, ideas, or help to share it would be greatly appreciated. My last question, since I got such a great deal on the phone, should I just quit complaining and be happy with what I have?
Thank you
Thank you
