Hi All,
I recently received an Android update on my Galaxy S5 making it run on Android 6.0.1. Shortly after that I noticed that the screen rortation feature does not work any more, regardless of whatever settings I use. I read about simular issues with earlier (ancient) updates to Android 4.* on some Galaxy models, but could not find anything about the 6.0.1. update. Does any one know about this bug or can any one suggest a solution? Is there any way to test if the sensor is to blame?
A further issue is memory related. Although the S5 should have 2 Gb of working memory, Apps such as the Piriform CC Cleaner ony are showing something like 1,6 Gb. Anything wrong with the memory or is there another explanation?
Regards,
Dave
The Netherlands
Regards,
Dave
The Netherlands
