Help Galaxy S8 - How to change the audio output device?
GamerCore
Okay, so I'm trying to use the separate app sound feature on the Galaxy S8, but every time I pick Spotify as the app, and Bluetooth speaker as the audio device I get this notification (below).
Android system is telling me I need to change the audio output device in order to make this work and that the option is available in the quick settings panel (which it's not).
Just so we're clear, I'm trying to play Spotify through my Bluetooth speaker, while having every other app play sound through my handset speaker.
According to Samsung's separate app sound feature, this is how it should work.... right? Oddly enough, it works in the other way around (telling separate app sound to play a specific app through my handset speaker).
Does anybody know how to change the audio output device in order to make separate app sound work properly?
