GamerCore
The Galaxy S8's Quick Settings tiles are located in the notification shade. Swiping down twice will display a full page of your Quick Settings, allowing you to tap them to toggle basic device functions like the WiFi, Airplane mode or flashlight.
It's possible to reorder these tiles (or add new ones) by doing the following:
To change the order, simply long press on a toggle and drag it around. Once you're finished, tap DONE in the upper right corner to save.
It's also possible to change the how many toggles are displayed at once.
- Swipe down twice
- Tap the 3-dot menu in the upper right corner
- Select Button order
- Swiping down twice
- Select Button grid
- Choosing one of the available options: 3x3, 4x3, or 5x3
