futurefrogman
Hello all!
I am new to this forum and I have no idea where else to go. My Galaxy S2 side button will no longer power the screen off. Instead it will bring up the shut down/reset dialog box on the first press, which I back out of, then press the side button again and nothing happens for about two seconds. After the two second pause, the notification light flashes pink then my phone resets. My phone only resets when the side button is pressed. Primarily after two presses, but sometimes after just one. If I let the screen just shut off on its own, then it doesn't reset, so it is a problem with the button's function. I have already tried a factory reset and the problem has persisted. I have looked throughout all the forums and I cannot seem to find anything on this particular issue...
Side note, this phone is actually a replacement phone because my last S2 had a problem where it just consistently reset itself over and over. Is there a problem with the Galaxy S2 in general? I don't want to have to wait for a replacement for my replacement and I do not want to pay another $50 for a phone, since the first replacement obviously didn't work...
How can I fix this issue?
