hi
My galaxy sl is not connecting via samsung kies it says that run the usb debugging mode but when I do that, it isn't detected at all.
also when using mass storage, if I copy files to micro sd then it shuts down and says some trouble is there with the card however when i copy from internal memory to memory card, everything is fine. also the connection is lost when this error appears, I've to remove the cable then reconnect to get it working :S
help Me out!
help Me out!
