Kanastrous
Okay, looked at the existing threads and didn't find quite the right problem addressed.
So first, the stats:
Galaxy Tab 10.1
Model # GT-N8013
Android Version 4.1.2
Kernel Version 3.0.31-813049 se.infra@SEP-63 #1 SMP PREEMPT Wed Sep 25 20:54:30 KST 2013
Build number JZ054K.N8013UEUCM13
Bluetooth has worked for the last week, but like the title says, Bluetooth now won't turn on. If I tap the Bluetooth button on the pop-up menu from the lower right screen, the button remains dark and nothing happens.
Now that I have gone to Settings to turn it on with the slider switch, the message in the right-hand window says "Turning on Bluetooth..." and has been saying it for a half-hour with no progress. And now the little slider switch doesn't respond at all.
I would try a reset but the only apparent option is the "Factory data reset" and I don't know if that will help, and also prefer not to purge all of my settings and data.
And advice or suggestions would be very much appreciated.
Thanks!
Galaxy Tab 10.1
Model # GT-N8013
Thanks!
