Help Galaxy tab2 (p3100) WiFi issue when using with GSM network
jackscorp
I have problem connection to my WiFi when I use my device with any GSM network SIM card.
Settings app will keep saying that it is connecting and the connection will never succeed. If I turn-off and turn-on the WiFi for couple of times WiFi may connect again.
The problem won't go away even after removing the SIM card. Doing a factory reset (without the SIM card) will clear this problem (WiFi will connect properly). But If I put the SIM card back, the same problem will come again.
Does any of you face this issue with you p3100 ? (mine is p3100 - India)
Hi jackscorp - I moved your thread into the Support & Troubleshooting area where I am hoping that someone can help you out.
And welcome to Android Forums!!
