Root Galaxy Y and G. Pocket - interchangeable tools
mai77
S5300 and S5360 are very similar models.
you may want to try ODIN ver.3 and try to flash stock roms from SAMMOBILE.
try to get core dumps and publish them here so the Galaxy Y users can compare and tell you which firmware parts are reuseable.
please use all available tools to get debug output from model "G. pocket"
probably much stuff from Y world can be used for pocket as well.
what is the cpu name ?
Broadcom BCM21553, 832MHz CPU and Videocore IV GPU BCM2763 like in Y ?
on xda there was some discussion already about SGP tech aspects. use latest splitfus.exe to odinize stock roms.
SGP has a different partition layout and supports ext4fs seemingly. still many things are somewhat similar.
keep posting debug dumps kernel dumps from yaffs explorer asf.
pls document all entries in "factory mode" tweak apk and try secret codes on SGP
