Hello,
Im currently using the native calendar app. I am syncing my laptop iCal calendar -> Google Calendar -> Native Android Calendar app on my phone. When I go to "accounts and sync" I do not see an auto sync option. I just see a slider at top that I can select to turn syncing on or off.
My calendar doesn't seem to be immediately syncing when I make new events on iCal (which does immediately create a calendar event on my google calendar)
So my question is - How do I make my calendars automatically sync?
And if they are automatically syncing (I cannot find any settings on my phone that enable "auto sync" but sync is green in my notification bar) how often is the calendar app syncing with my google calendar?
Also on a side note, are there any applications that can sync multiple iCal calendars to my google calendar? So my events can be color coded etc, Ive been looking for something like this for awhile.
Thanks for any tips/suggestions
I am on T-mobile
I am on T-mobile
