[GAME][2.1+] Blobby Volleyball with Wi-fi and Bluetooth
AppsOn
Hello
We would like to introduce you our new game - Blobby Volleyball. It is great volleyball game with dynamic gameplay and friendly controls.
Features:
- Versus Mode - three levels of difficulty bots
- Angry Mode - try to score as many points as you can with angry bot without losing a point (LeaderBoard integrated with OpenFeint)
- Mirror Mode - try to score as many points as you can controlling two players at the same time (LeaderBoard integrated with OpenFeint)
- Multiplayer - play against other person using Bluetooth or Wi-Fi (If you're behind router, you need to open port 27454 in order to host game for someone from outside your LAN. Link to tutorial: Port Forwarding Guides Listed by Manufacturer and Model - PortForward.com)
- Achievements integrated with OpenFeint
- Three types of control (slider, sensor and arrows)
LINK:
https://market.android.com/details?...sMSwxLDEsImNvbS5hcHBzb24uYmxvYmJ5dm9sbGV5Il0.
We would like to read your opinions on this game and hear about improvments you would like to see. Thanks :)
There were some updates recently, so here are some explainations on fixes that were made:
UPDATE 1.2:
- fixed lowering of texts and ball indicator, when add is displayed, for various screen dpi
- fixed hints display in menu (didn't show sometimes)
- bt devices list is fixed now for long names
- after installing the game OpenFeint is now disabled by default (in order to enable it, check "Use OpenFeint" in options menu)
- fixed some graphics (hints' pointers were not suited to text length)
UPDATE 1.3:
- bt devices list is fixed (non-ascii chars are replaced with '?' now until we find better solution)
Also we are modifying steering and adding new one right now as some users requested. So if everything will go ok, in matter of day or two you should be able to experience the gameplay in the way that fits you best. Stay tuned!
And here comes another update. It brings few fixes and some new features. Details below.
UPDATE 1.5:
- added steering with arrows (buttons)
- slider steering has been modified, so now you can jump using button on the opposite side of screen
- now, apart from choosing player side, you can choose side on which you want to have steering (applies to slider and arrows)
- other minor changes not worth mentioning ;)
Yet another update. As promised, we bring to you ability of playing over Wi-Fi, and few other things. Description below.
UPDATE 1.6:
- added multiplayer over Wi-Fi
- changed looks of some menus
- bluetooth device list can be scrolled in android style now
- fixed bt device list (as usual, non-ascii characters)
- changed difficulty of bots
- arrow buttons' hitbox is now doubled
- added restart button to all types of games (in multiplayer only server can restart the game)
Of course this is not the end. Lots of improvements are planned for nearest future, so you shouldn't be disappointed. Enjoy :)
Note to Wi-Fi:
And here it comes, yet another update.
UPDATE 1.7:
- added steering with physical keyboard (used keys can be seen in help in options menu - steering section)
- few fixes to bluetooth and wi-fi
- added some hi-res textures (blobby, ball and minor menu elements)
