Connect your Droid to the PC via USB. Your phone should 'bing' and a notification will appear at the top of the screen. Drag the screen down and touch the USB icon. Select MOUNT option, and you should see a new drive icon appear on your PC. That drive is your phone's SD card. Create a folder called games/gba in that drive and copy the GBA bios and any other ROM games into it.
Right click the SD drive icon and select EJECT. Drag the notification bar down on your phone, select USB and UNMOUNT.
Run your GBA emulator and select the bios in games/gba folder
Maybe I have a bad bios file? where can I get one?
I wanted to know where I can get gameboid roms and the BIOS I can't find one plz help
Hey Plz relpy
I was wondering if you have to download the Bios directly from the phone. Or could you do it via computer. Also do you have to pay to update Gamboid, and how do you update it.
Hi!
I installed the gameboid on my HTC Sensation and got the bios and everything.
Now when I want to launch a game like Pokemon I click on'gameboid' in my app list, then select 'Pokemon ... .gba' and then i have a black screen for a secong, then it says 'gameboid is running.' in the notification bar at the top but now nothing happens ...
what am I doing wrong?
i tried doing what you said, but when i clicked on the usb icon, it didn't give me the option "mount". :/ now i'm lost.
Hey Plz relpy
