GameCIH and temple run problem
I rooted my kindle fire recently, and I downloaded GameCIH to get coins for temple run. I started the game, got a couple of coins, then paused my game and hit "input number" on GameCIH. I continued the game, got a few more coins, then hit the plus sign on GameCIH. I continued going back and forth and hitting the plus sign a few times, and then found the number that matched my current amount of coins and replaced it with nines. I ended up with over a million coins, and I proceeds to unlock everything. Then I tried for more coins using the same process. The third time I did this, my coins were negative. I can no longer buy anything. I have negative two million coins. Did I do something wrong? Is there a way to fix this? I've already tried just doing in again, but it made it worse.
