Hello,
I am coding an application that is running on a Nexus10. I don't think that matters. I am using Android version 4.4.2.
I am experimenting with using a fragment to display a common group of TextViews that are displayed as the top 3 elements of an Activity that uses a LinearLayout. I am not doing anything formatting outside of the following two LinearLayout XML snippets. In the first (the parent level) I have a fragment and two text views. There is a huge gap that shows up between the fragment and the TextViews. If I remove the android:layout_height="0dp" and android:layout_weight="1" attributes from the fragment tag then the fragment doesn't get displayed at all. Does anyone see why I might be getting this huge gap between the fragment and the two TextViews displayed below it? Thanks!
Here is a the parent (Activity) level Layout. And below it is the fragment specific layout.
[HIGH]
<?xmlversion="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_height="match_parent"
android
rientation="vertical" >
<fragment
android:name="com.srcinc.drphilos.ChemicalNameAndCasNumberFragment"
android:id="@+id/chemical_name_and_cas_number"
<TextView
android:id="@+id/healthEffectsSummaryLabel"
android:textStyle="bold"
style="@android:style/TextAppearance.Medium"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
<TextView
android:id="@+id/toxletText"
[/HIGH]
And following is the fragment specific layout.
[HIGH]
<LinearLayout xmlns:android=http://schemas.android.com/apk/res/android
android
<TextView
android:id="@+id/chemicalName"
style="@android:style/TextAppearance.Large"
android:layout_height="wrap_content"/>
<TextView
android:id="@+id/casNumberText"
<TextView
android:layout_width="fill_parent"
android:layout_height="5dp"
android:background="#DADADA" />
</LinearLayout>
[/HIGH]
[HIGH]
android
rientation="vertical" ><fragment
<TextView
<TextView
[/HIGH]
[HIGH]
android
rientation="vertical" ><TextView
<TextView
<TextView
</LinearLayout>
[/HIGH]
