Garbled Phone Converstion
Donjo
Member
I have been having issues with my Verizon LG G2 with reception. Every time I am having a conversation, no matter where I am with reception, if we are talking at the same time the reception becomes very garbled. They can hear me just fine but I have to have them repeat themselves as it was completely inaudible. I have had these on my previous phone Razr Maxx as well and this is with full bars. Does anyone have a quick fix for this?
There is no "quick fix"... you have one of only a handful of issues.
An app conflit, probably in common from your old device, that is causing the issue, like a call recording app
A OS configuration fault, a factory data reset would be required.
A faulty SIM card, Verizon can/will replace it.
A defective device, you should seek a warranty replacement.
Garbled audio is not normal at all, I have had less than 10 "garbled" calls in the last 3 years (not counting poor signal, obvious issue on the other end, etc), and I make a lot of calls, this is unacceptable and you should contact Verizon if you can verify it isn't something on your end.
