Root Gb roms!!!! =d
So i was looking on drewgaren.com at the 3 GB roms he has going on.
Broodcomb v1.0 looks the best i think but i dont think he released it yet? anyone know when it will be out?
Zapx looks good but idk
what do you think i should do? should i wait for Broodcomb?
Is there a toolbox so i can easily reinstall the Blur apps/widgets that i like?
or should i just Deodex and get the Gingercomb theme?
Ive heard mixed reviews of his stuff. One thing for sure is if you do load on of his ROMs you need to factory reset in stock recovery after. Read the sticky at the top about recovery changes in GB.
Otherwise I have heard almost everyone say it will reboot like crazy if you don't.
