gdocs problem
rcyphermd
Android Expert
I am using gdocs and like it. However, it has only synced over about half my notes on goggle documents. Any idea what I can do to solve that?
Also, is there a way to have "hidden" file on the hero like on google documents?
i had corrupt files and simply deleted then (restart) then reinstalled and let if finish syncing before i opened it. seems to have fix it. I wish i could put a password on gdocs. haven't seen anything in there to hide either.
I deleted it and then rebooted and downloaded again. Same result.. it only.syncs half of them. Any other suggestions? Thanks for trying
My experience with Gdocs is that it only pulls down the docs you view. Try opening one of the docs that haven't synced and see if it downloads.
You can also long-tap on a document title and then tap download. Do that for all your documents (or at least the ones you want locally stored on the phone).
According to the help, the sync button only serves to upload documents that you have changed on the phone. It doesn't cause anything to be downloaded.
There doesn't seem to be a true bi-directional sync available. Hopefully that will be fixed soon.
