Not to worry, the "GPS" will work just fine, it's the aGPS that's messed up. Which is useless for nav any how. And a fix for that is in the works.Gotcha. Thank you! Good thing I have a Garmin to fall back on.![]()
Engadget says the aGPS is turned off by default and the GPS is working fine.Actually, reading the new reviews on the Epic 4G, everyone who tested GPS/aGPS says it is working great.
Maps will give directions, but Google Nav gives turn-by-turn as does Sprint Nav It's a matter of personal choice as to which one you want to use. I prefer google Nav it has a 3-D effect that makes it look like you're flying above the route (satellite Mode Layer).Are issues the result of a software glitch, or is the phone not being picked up by satellites?? Are there GPS apps out there? Does that Google Maps app give directions?
But I never use Wireless networks for location when in NAV mode. Just use GPS (much more accurate). aGPS is good for when You only need a ballpark like weather programs etc. With Radioactive Froyo 1.8.7 my moment is locking on virtually within a second or two. And it's accuracy is almost perfect.Yeah, but they mean you have to go into settings and toggle "GPS assistance" to on. Similar, to how you can toggle it on and off on the Moment.
Originally they reported that they could not get a lock, so they called up Samsung, who reported that aGPS is factory turned off (Sprint requirment), so they went and turned it on in settings, and were able to quickly get a lock and after that GPS worked great.
Whenever I have a problem getting a quick lock, I just start up GPS Test--That does it for me! But, I haven't even needed that lately. Comes from my old HTC Touch days.I was just saying that aGPS (it appears) is not a problem in Epic, as Engadget's update confirmed. Turning on aGPS for them resulted in a faster lock.
I do agree though, aGPS gives a massive radius of accuracy, which messes with NAV horribly. Though usually after aGPS gets a lock, GPS locks in for a much smaller radius.
There is a huge definition gap between working and not working. Some people think that just because they get a blue arrow that it's working. I don't agree with this. It needs to be locked to 5 meters or less (you can press and hold the blue arrow to find out what the lock radius is). Otherwise, apps like golf GPS is worthless.I was just saying that aGPS (it appears) is not a problem in Epic, as Engadget's update confirmed. Turning on aGPS for them resulted in a faster lock.
BTW, I wouldn't trust the Engadget review too much. They're pretty dumb. They couldn't get the USB to mount on the Captivate and couldn't do it with the Epic. I mount my Captivate to my Mac all day, every day and it's easy as pie to drag and drop files.
You still don't get it.I totally agree that Endgadget is not very trustworthy, however, SlashGear and PcMag are also reporting GPS as working great.
I can not believe that engadget thinks turning on wireless networks is the answer to the GPS bug.
This is completely embarassing for them.
All they have to do is grab 5 other Android phones, turn off wireless network locations on all, and only turn on GPS. They will all work flawlessly, except for the Samsung Galaxy S phones.
How can engadget make such a mistake in thinking this was the solution to the GPS bug. It is nothing more a cover up, using wireles network locations, to mask the true GPS bug.
I CAN'T BELIEVE WHAT I READ!![]()
If you look at the pics in the Slashgear review, it shows that WIFI is turned on. This can aid tremendously in triangulating the location for GPS. If they did test GPS with WIFI on, then it's an invalid test.I totally agree that Endgadget is not very trustworthy, however, SlashGear and PcMag are also reporting GPS as working great.
Can't wait for the phone to come out!!
Can you read?I am wondering why dietcoke can say the GPS is 'broke' on this phone when he doesn't have one in his hands either. He is basing it on the fact that he has a different galaxy s phone. So apparently because one has an issue all of them have to?
