Generic Chargers for the Incredible
DHall15
Hi all,
I have a bunch of mini USB charges (car ect) you can buy and adapter from Mini to Micro for a few bucks. I have not owned an HTC phone before, do they accept generic chargers? Do you think I will have any problem using an adapter to charge the phone.
Just trying to get out of buy a lot of $30 chargers.
Thanks
They will probably work with most of your chargers. I bought a bunch of those mini-to-micro adapters and they work pretty good. It really depends on the Amperage output of the charger as to the performance (how long it takes to charge) of the setup.
I have had some problems with some of the super super cheap car chargers, but it should work fine for most of the mini-chargers you have now.
Check the volts and amps etc. Just because it's the same usb adapter, does not mean it's the same current. Most of them do not give the usb standard power (0.5) amps. Just make sure it doesn't give more than the wall adapter that comes with your phone.
