helpfordroid
We will really appreciate if you provide us feedback to our application.
Gesture control of mobile apps setting switches, provide widgetThe application Gestures Way is there to use your smartphone smartly and fastly.
The main functionality of the application is to provide faster access to the application,
phone settings and the switchers like Wifi, Bluetooth... by specifying the gesture for it.
The elements with gesture can be simple run by writing the specified gesture in the gesture dialog.
Gesture dialog can be executed automaticaly after unlock the phone, clicking to the application
widget or executing from the information displayed in the status bar. All these possibilities
can be set in the configuration of the application.
The application, settings and switchers can be added to the favorites list, and this elements
will be showed at the bottom part of the gesture dialog, so you can simply execute them
by one click.
Features:
* launch application by gesture
* launch phone settings by geture
* enable/disable wifi, bluetooth, gps, auto-rotate screen by gesture
* widget
* gestures dialog executable from activity bar
* automatic displaying gesture dialog after unlock the phone
by one click.
Features:
* widget
