GestureControl allows you to control tablet or phone with MULTITOUCH gestures.
Root required.
You can execute following default gestures:
Previous application: Swipe 4 fingers right
Next application: Swipe 4 fingers left
Show/Hide status bar: Swipe 3 fingers upward (ICS support is in Alfa stage)
Back: Swipe 3 fingers downward
Home: Pinch 4 fingers
Launch Pad: Expand 4 fingers
You can also create your own custom gestures and assign custom actions: LaunchPad, Start application, Home, Kill current application, Back, Forward, Recent application list, Recent application dialog, Menu, Notification Panel, Hide/Show status bar, Start launcher shorcut(bookmark, contacts, settings, etc), Start Tasker task, Pause gestures, Exit, Screen Off (lock), Previous application, Next application, Play/Pause music, Previous song, Next Song.
If you like my application, please rate it in market. Thanks.
Market:
Gesture Control Lite
Direct download:
Download - Gesture Control Lite
USB Debugging must be enabled
Known issues on ICS:
- Hiding Bar gesture will remove home screen wallpaper.
- Hiding Bar gesture will reset your wallpaper to default.
There is no problem with Live Wallpaper. I suggest using "simple image wallpaper" from market on ICS, that will fix wallpaper disappearing (it is Live Wallpaper based still image).
Root required.
Market:
Direct download:
