You probally would have more luck in the optimus s section but what you do is from power off press and hold power home and volume down. Now if you dont have a custom recovery it will reset your phone back to stock and delete everything. If you do have a custom recovery it will boot into that
The guys above have the keystrokes right, but when I've used it, it was very difficult to hold those awkward keys properly. I kept trying until I got it to work, but it wasn't easy.
