Apps getAltitude() help
Marker88
i want to have it so when you press a button it puts it into a textview so far i got this
Code:
package Android.sdk;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.TextView;
import android.location.Location;
public class Android extends Activity {
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.main);
        final Button button = (Button) findViewById(R.id.Button);
        button.setOnClickListener(new View.OnClickListener() {
            public void onClick(View v) {
                TextView tv = new TextView(this);
                double altitude = 0.0;
                Location.getAltitude() altitude = new Location.getAltitude();
               tv.setText(altitude);
                // Perform action on click
yeah, what do i need to change?
add a textview to the main layout and refer to it the same way you did with the button
TextView tv = (TextView) findViewById(R.id.text);
then you gotta convert your value you wanna post to a String and have
tv.setText(string_value);
im kinda new so you have to go slow, how do i turn getaltitude() into a string? heres my new script
Code:
import android.view.View.OnClickListener;
    @Override
    	final TextView tv = new TextView(this);
                tv.setText("hi");
                setContentView(tv);
it runs, but how do i add it so "hi" shows up as your altitude?
I've never used getAltitude() but assuming it returns a a normal data type you can do this
Code:
tv.setText(altitude + "");
It also depends on your Location Service. First of all this doesn't make much sense
Code:
You should do something like this instead:
Code:
LocationProvider locationProvider = LocationManager.GPS_PROVIDER;
Location lastKnownLocation = locationManager.getLastKnownLocation(locationProvider);
lastKnownLocation.getAltitude();
This requires that your device's GPS is turned on! Which is required anyway, as you cannot get any real altitude readings from a network based location.
To transfer the return value of .getAltitude() , which returns a Double value, you could also use this:
Code:
alt = Double.toString(lastKnownLocation.getAltitude());
Way more useful stuff on this here:
Obtaining User Location | Android Developers
so i put in
Code:
        String locationProvider = LocationManager.GPS_PROVIDER;
Location lastKnownLocation = LocationManager.getLastKnownLocation(locationProvider);
but no matter where i put it it gives the error non-static content cant be referenced in static content
Maybe reading and learning the basic of Java Programming for Android will help you a lot.
