krishnaveni
I have to develop one android application.
Its performs the attribute value is display on listview...
This is my xml tags:
I have used below code:
[HIGH]
public class MainActivity extends Activity {
String URL;
static String KEY_CATEGORY = "Categories";
ArrayList<HashMap<String, String>> songsList;
static final String KEY_PNAME = "Category";
static final String KEY_PRICE = "Description";
static final String KEY_THUMB_URL = "thumb_image";
ListAdapter adapter;
/** Called when the activity is first created. */
@Override
// TODO Auto-generated method stub
setContentView(R.layout.activity_main);
songsList = new ArrayList<HashMap<String, String>>();
HorizontalListView list = (HorizontalListView) findViewById(R.id.listView1);
adapter = new ListAdapter(this, songsList);
list.setAdapter(adapter);
URL="http://webservices/new_feed_articls.xml";
XMLParser parser = new XMLParser();
String xml = parser.getXmlFromUrl(URL); // getting XML from URL
Document doc = parser.getDomElement(xml);// getting DOM element
NodeList nl = doc.getElementsByTagName(KEY_CATEGORY);
// looping through all song nodes <song>
for (int i = 0; i < nl.getLength(); i++) {
// creating new HashMap
HashMap<String, String> map = new HashMap<String, String>();
Element e = (Element) nl.item(i);
// adding each child node to HashMap key => value
map.put( KEY_PNAME,((Element)nl.item(i)).getAttribute("name"));
map.put(KEY_PRICE, parser.getValue(e, KEY_PRICE));
map.put(KEY_THUMB_URL, parser.getValue(e, KEY_THUMB_URL));
// adding HashList to ArrayList
songsList.add(map);
// Click event for single list row
list.setOnItemClickListener(new OnItemClickListener() {
@Override
public void onItemClick(AdapterView<?> parent, View view,
int position, long id) {
HashMap<String, String> map = songsList.get(position);
[/HIGH]
Here i have to run the app means the category name is displayed on listview.How can i get the attribute value ??? please help me.
I got the below error:
<root>
<Categories>
<Category name="books">
<Articles>
<article articleid="170" title="Colour And Vibrancy Are Part Of Our DNA">
<Description>
Well-known interior designer
</Description>
[HIGH]
String URL;
@Override
songsList.add(map);
@Override
[/HIGH]
02-04 10:51:11.859: I/ActivityThread(2803): queueIdle
02-04 10:51:11.859: V/ActivityThread(2803): Reporting idle of ActivityRecord{4a4a92d8 token=android.os.BinderProxy@4a4a8df8 {com.example.notch/com.example.notch.MainActivity}} finished=false
02-04 10:51:11.859: W/ActivityNative(2803): send ACTIVITY_IDLE_TRANSACTION
02-04 10:51:11.869: V/ActivityThread(2803): Reporting idle of ActivityRecord{4a4a92d8 token=android.os.BinderProxy@4a4a8df8 {com.example.notch/com.example.notch.MainActivity}} finished=false
02-04 10:51:11.869: W/ActivityNative(2803): send ACTIVITY_IDLE_TRANSACTION
02-04 10:51:11.869: I/ActivityThread(2803): queueIdle
02-04 10:51:11.919: W/System.err(2803): java.net.MalformedURLException: Protocol not found:
02-04 10:51:11.929: W/System.err(2803): at java.net.URL.<init>(URL.java:275)
02-04 10:51:11.929: W/System.err(2803): at java.net.URL.<init>(URL.java:159)
02-04 10:51:11.929: W/System.err(2803): at com.example.notch.ImageLoader.getBitmap(ImageLoader.java:67)
02-04 10:51:11.929: W/System.err(2803): at com.example.notch.ImageLoader.access$0(ImageLoader.java:55)
02-04 10:51:11.929: W/System.err(2803): at com.example.notch.ImageLoader$PhotosLoader.run(ImageLoader.java:132)
02-04 10:51:11.929: W/System.err(2803): at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
02-04 10:51:11.929: W/System.err(2803): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
02-04 10:51:11.929: W/System.err(2803): at java.util.concurrent.FutureTask.run(FutureTask.java:137)
02-04 10:51:11.929: W/System.err(2803): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1068)
02-04 10:51:11.929: W/System.err(2803): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:561)
02-04 10:51:11.929: W/System.err(2803): at java.lang.Thread.run(Thread.java:1096)
02-04 10:51:40.579: W/IInputConnectionWrapper(2803): getExtractedText on inactive InputConnection
02-04 10:51:45.679: W/IInputConnectionWrapper(2803): getExtractedText on inactive InputConnection
