Getting a replacement phone and copying over
attroll
Member
My Note 9 screen shattered and I am waiting for my replacement phone. I should get it within a day or two. It will be the same style Note 9.
I have had phones replaced in years past by my insurance but it has been over five years since I have had to do it.
In the past I had to copy all my photos and data files to a hard drive and then copy them back to the new phone. Then I have to make a list of the programs that were install on the bad phone and reinstall them one by one onto the new phone. It was a real pain in the butt to get everything copy over to the new phone and install the same programs to make it identical to the phone I was replacing.
I am hoping that things have change since I last had to replace a phone. Is there any program out there that will copy everything over and make it identical to the phone I am replacing?
yep it is called smart switch
also i would really recommend using google photos. it will sync all of your photos to the cloud. i never have to copy or do anything to my photos. they are automatically backed to the cloud is you select that option. i can even take a photo, wait for it to sync to my computer, and then hop onto my pc to see the photo without having to connect anything to the computer.
Thanks for the quick reply. I do backup have my photos go to Google. I also have my photos save to my external card on the phone.
The issue is not really the photos. It's the data files for the apps that I have installed. I don't want to lose those.
Will the Smart Switch copy all my app directories and apps to the new phone or am I going reinstall the apps on my new phone one at a time still?
it will download and install your apps as well as your data.
https://www.samsung.com/us/support/owners/app/smart-switch
