aliveon2legs
I successfully obtained S-Off with Revolution. After that my intent was to try to get root using the SU zip file from the Revolution website. The first time I tried to go into recovery I got this icon, but it went away after a couple of minutes. When I tried to install the SU zip it failed, though.
The second time I tried to go into Recovery I accidentally did a factory reset, as my volume button tends to scroll down twice when you hit the button once. :banghead:
After it was done resetting I went back into HBOOT again. It was still set to S-Off. I tried to go into Recovery once more and got the triangle symbol again. This time it doesn't seem to be going away. It's been there for a half hour or so, now. I'm afraid to pull my battery because of a bricking experience I had on a previous phone.
I need some quick advice! Thanks.
