Apps getting error while using viewHolder in sqlite based application
hi friends
i tried to design a simple a sqlite related apps .but when i try to inflate my data in listview using view holder.it's getting error.i cannt understand how to debug it. please help me
my code is---
1- code for SQLiteOpenHelper
Code:
public class DataHelper extends SQLiteOpenHelper {
    public static String DATABASE="kuldb";
    public static String DB_TABLE="friends";
    public static String COL_id="id";
    public static String COL_NAME="name";
    public static String COL_ADD="address";
    public static String COL_PH="call";
    ArrayList<FriendModel>cartlist=new ArrayList<FriendModel>();
    Context c;
    public DataHelper(Context c){
        super(c,DATABASE,null,1);
    public void onCreate(SQLiteDatabase db){
        db.execSQL("create table friends(id integer primary key autoincrement,name text,address text,call text)");
    public void onUpgrade(SQLiteDatabase db,int oldv,int newv){
        db.execSQL("drop table if exist "+DB_TABLE);
        this.onCreate(db);
    public void putfriends(FriendModel fritype){
        SQLiteDatabase sd=this.getWritableDatabase();
        ContentValues cv=new ContentValues();
        cv.put("name", fritype.friname);
        cv.put("address", fritype.friadd);
        cv.put("call", fritype.friph);
        sd.insert("friends", null, cv);
        sd.close();
     public void updatefri(FriendModel frilist){
         cv.put("name", frilist.friname);
         cv.put("address", frilist.friadd);
         cv.put("call", frilist.friph);
         sd.update("friends", cv, "name="+ frilist.friname, null);
         sd.close();
     public void emptyfriends(){
         try{
         sd.execSQL("delete from friends");
         sd.close();
         }catch(Exception e){
             e.printStackTrace();
     public void removefriend(String fname,String fadd,String fph){
         try{
         String[]arg={fname};
         sd.delete("friends", "name=?", arg);
         sd.close();
      public ArrayList<FriendModel>getallfriends(){
          cartlist.clear();
          Cursor c=sd.rawQuery("select * from friends", null);
          if(c.getCount()!=0){
              if(c.moveToFirst()){
                  do{
                      FriendModel type=new FriendModel();
                      type.friname=c.getString(c.getColumnIndex("name"));
                      type.friadd=c.getString(c.getColumnIndex("address"));
                      type.friph=c.getString(c.getColumnIndex("call"));
                      cartlist.add(type);
                  }while(c.moveToNext());
          c.close();
          sd.close();
          return cartlist;
2- code for MainActivity
Code:
public class MainActivity extends Activity{
    EditText fname,fadd,fcall;
    Button fsave,fview;
    FriendModel fm;
    DataHelper help;
    public void onCreate(Bundle b){
        super.onCreate(b);
        setContentView(R.layout.main);
        fname=(EditText)findViewById(R.id.addname);
        fadd=(EditText)findViewById(R.id.addcity);
        fcall=(EditText)findViewById(R.id.addph);
        fsave=(Button)findViewById(R.id.savedata);
        fview=(Button)findViewById(R.id.viewdata);
        fsave.setOnClickListener(new OnClickListener() {
            @Override
            public void onClick(View v) {
                // TODO Auto-generated method stub
                if(fname.getText().toString().equals("")
                        ||fadd.getText().toString().equals("")||fcall.getText().toString().equals("")){
                    Toast.makeText(MainActivity.this, "please Fill All data fields", Toast.LENGTH_LONG).show();
                else{
                    help=new DataHelper(getApplicationContext());
                    help.getWritableDatabase();
                    fm=new FriendModel();
                    fm.friname=fname.getText().toString();
                    fm.friadd=fadd.getText().toString();
                    fm.friph=fcall.getText().toString();
                    help.putfriends(fm);
                    Toast.makeText(MainActivity.this, "Records Added sucessfully", Toast.LENGTH_LONG).show();
                    fname.setText("");
                    fadd.setText("");
                    fcall.setText("");
        fview.setOnClickListener(new OnClickListener() {
            @Override
                Intent i=new Intent(getApplicationContext(),ViewFriends.class);
                          startActivity(i);
code for FriendModel class
Code:
public class FriendModel {
    public String friname="";
    public String friadd="";
    public String friph="";
    public String getfriname(){
        return friname;
    public void setfriname(String friname){
        this.friname=friname;
    public String getfriadd(){
        return friadd;
    public void setfriadd(String friadd){
        this.friadd=friadd;
    public String getfriph(){
        return friph;
    public void setfriph(String friph){
        this.friph=friph;
code for final ViewFriends classs--
Code:
public class ViewFriends extends Activity{
    TextView totalfans;
    ListView listview;
    DataHelper help;
    ArrayList<FriendModel>friendlist=new ArrayList<FriendModel>();
           super.onCreate(b);
           setContentView(R.layout.view_record);
           totalfans=(TextView)findViewById(R.id.totalrecords);
           listview=(ListView)findViewById(R.id.listview);
       public void onResume(){
           super.onResume();
           friendlist.clear();
           ArrayList<FriendModel>fanlist=help.getallfriends();
           for(int i=0;i<fanlist.size();i++){
               String tfname=fanlist.get(i).getfriname();
               String tfadd=fanlist.get(i).getfriadd();
               String tfph=fanlist.get(i).getfriph();
               FriendModel fan=new FriendModel();
               fan.setfriname(tfname);
               fan.setfriadd(tfadd);
               fan.setfriph(tfph);
               friendlist.add(fan);
           totalfans.setText("Total Records Found: "+friendlist.size());
           listview.setAdapter(new ListAdapter(this));
           help.close();
       private class ListAdapter extends BaseAdapter{
           LayoutInflater inflater;
           ViewHolder viewholder;
           public ListAdapter(Context c){
               inflater=LayoutInflater.from(c);
        @Override
        public int getCount() {
            return friendlist.size();
        @Override
        public Object getItem(int position) {
            return position;
        @Override
        public long getItemId(int position) {
            return position;
        @Override
        public View getView(int position, View convertView, ViewGroup parent) {
            if(convertView==null){
                convertView=inflater.inflate(R.layout.item_record, null);
                ViewHolder viewholder=new ViewHolder();
                viewholder.tfriname=(TextView)convertView.findViewById(R.id.namedb);
                viewholder.tfriadd=(TextView)convertView.findViewById(R.id.addressdb);
                viewholder.tfriph=(TextView)convertView.findViewById(R.id.calldb);
                convertView.setTag(viewholder);
            else{
                viewholder=(ViewHolder)convertView.getTag();
              viewholder.tfriname.setText(friendlist.get(position).getfriname());
              viewholder.tfriadd.setText(friendlist.get(position).getfriadd().trim());
              viewholder.tfriph.setText(friendlist.get(position).getfriph().trim());
              final int temp=position;
              (convertView.findViewById(R.id.update)).setOnClickListener(new OnClickListener() {
                @Override
                    String updatename=friendlist.get(temp).getfriname();
                    String updateadd=friendlist.get(temp).getfriadd();
                    String updateph=friendlist.get(temp).getfriph();
                    Intent in=new Intent(ViewFriends.this,Update.class);
                    in.putExtra("fname", updatename);
                    in.putExtra("fadd", updateadd);
                    in.putExtra("fph", updateph);
                    startActivity(in);
              (convertView.findViewById(R.id.delete)).setOnClickListener(new OnClickListener() {
                @Override
                    AlertDialog.Builder adb=new AlertDialog.Builder(ViewFriends.this);
                    adb.setCancelable(true);
                    adb.setMessage("Are you Sure about Delete Record???");
                    adb.setPositiveButton("Yes", new DialogInterface.OnClickListener() {
                        @Override
                        public void onClick(DialogInterface dialog, int which) {
                            help.removefriend(friendlist.get(temp).getfriname().trim()
                                    , friendlist.get(temp).getfriadd().trim(),friendlist.get(temp).getfriph().trim());
                            ViewFriends.this.onResume();
                            Toast.makeText(ViewFriends.this, "Record Deleted Sucessfully", Toast.LENGTH_LONG).show();
                    adb.setNegativeButton("No", new DialogInterface.OnClickListener() {
                        @Override
                    adb.show();
            return convertView;
       private class ViewHolder{
           TextView tfriname;
           TextView tfriadd;
           TextView tfriph;
