I bought this phone back in January. That makes it a little over 2 months old. It's been a great phone so far, but I've had a problem happen 3 times now that is a little bit concerning.
Out of nowhere, the phone will start getting really hot. And I won't even be using it. I'll notice that it's getting hot in my pocket. So I take it out, check the task manager to see what apps are running. There is nothing running, and the RAM status is normal, sitting at about 380mb.
While this bizzare heat thing is happening, the battery gets sucked down like crazy. I literally went from a full charge to 9% in about 4 hours. And I was probably actually using the phone for a total of 5 minutes in that time. I checked in the settings to see what has been using the battery, and 98% of the battery was used by the android system.
Anybody else have this problem? The phone is still under warranty, and I'm seriously considering taking this thing back to the store. This has happened 3 times in the past 2 weeks. But most days it's fine. But I have a feeling that this problem will get worse rather than better
