Certainly not just yet as KitKat hasn't been released
It depends on your device: if it's an older device (which the fact it has GB suggests it may be), then the hardware may not be up to running KitKat. Also, the fact it hasn't been upgraded since GB kinda suggests that the manufacturer and/or network have stopped supporting it.
On the other hand, if it's a popular device you may find that in the months after the release of KitKat some whizz kid may produce a ROM that will work. Keep an eye on the rooting section of your device's sub-forum on here.
I wouldn't be too concerned, though as Google have moved away from putting all the cool new stuff in Android releases: most of it has been moved to apps that are updated via the Play Store so you're probably not going to miss out on too much anyway.
