Gingerbread 2.3.4 issues
JBT80
Hi!
I've installed Gingerbread 2.3.4 DDKQ5 official update through ODIN and noticed that my phone is slower than on previous version of Android (Froyo). Except unlock screen lag, my battery drains faster, sometimes I hear strange sound during calls nad some apps loads slower. Because of that problems I've returned back to Froyo and now everything's fine.
I wanted to ask you did anyone experienced simmilar problems with GB on Ace?
so far no complaints yet on DDKQ5
after flashing you should factory reset and clear cache partition in recovery mode then reboot
others flash it twice just to make sure and do the same process.
use it till battery drains. do a full charge then do your observations after that.
you will notice only very minimal difference if you try to observe it directly after update. but after battery drain you will notice lots of difference.
