gingerbread for vodafone
What version of Android are you on? Key in *#1234# into the phones dialler and please post back the info.
Also, what message are you getting in Kies? It will either say " This is the latest version " or " This version of the device cannot be updated ".
Also, what country are you in?
All the best.
Ray
@loadsaaaTOP.
Vodafone released Gingerbread 2.3.3 in the UK on the 19th May, so you should be able to upgrade to it. First things first though make sure you are running the latest version of Kies. Grab a copy of the latest version from Mobile Phone's Software&Manual SAMSUNG
Just un-install your old version including the drivers and install the version you've just downloaded.
If that doesn't help then post back with the info I asked for in my first reply by typing *#1234# into the phones dialer.
All the best.
Ray
JPO means you are already on gingerbread my friend.
That's why kies isn't offering you an update.
All the best.
Ray.
Sorry my mistake JVO is gingerbread not JPO.
I will check it out a bit later when I get home, as you should be able to update.
Ray
