Since the gb Ota I can no longer program my voicemail to automatically enter my voicemail password whem checking voicemail. I have tried retyping the *86,,1234# but it does not work. It worked fine before the update. Any thoughts? Direction?
just out of curiosity have you tried manually entering and dialing it? i.e. entering the string as a "phone#" and pressing send? this way you could listen and see what the issue may be. (you may need one more or one less comma for example or the code may be wrong)
