i do not believe gingerbreak works with the intercept you can try the superoneclick application or theres that interceptroot.apk or you could download swupgrade and the patch and flash a custom recovery.tar and then flash a kernel that has root there are alot of benefits of rooting theres applications that allow you to control the phone in a way you couldnt otherwise like call blocking, tethering im pretty sure there is alot more
