CyberWinter
Member
Does anyone have any input regarding the Global feature of the S3? I know this phone is under various carriers, so I'd like to find out the pros/cons between the carriers in regards to the Global function. For example how does it work on AT&T and how does it work on Verizon.
I've read on Verizon, you're not able to pop a foreign sim card yet unless Sammy releases an update. Any input on this as well?
On AT&T are you able to simply take out the sim card and put in a foreign sim?
Thanks
Thanks
