Root gmail 4.2 is stuck in tablet mode?
droiddekka
i am getting the "dual pane" view of gmail and the text is a bit smaller than normal.
this is after a fresh DU2.0 flash and i'm scratching my head.
what's the damn deal?
i already toggled "dual window UI" in the rom control settings and rebooted. i have uninstalled and reinstalled various 4.1 and 4.2 versions of gmail. both regular and inverted.
I had that same problem and started messing around in Dirt Settings - Hybrid Settings - Per App Layout - Find gmail and click it and it should say 360 and 600 click on the 360 because that's phone mode and 600 is tablet.
If you what to change the dpi of the app go to Dirt Settings - Hybrid Settings - DPI Groups then click on the one you want then put gmail it in.
That should work because I just tried to to make sure I was right about it.
righteous man that fixed the dual pane problem but i am still getting smaller than usual text, again only in gmail. the rest of the phone is normal, and the gmail dpi settings are identical to every other app in the list.
sigh.
