Is there a way to set gmail invites to be private by default? Google help says that if your calendar is set to private (mine is) then all invites will be private too. That is not the case though - when my husband receives an invite in Outlook and he has to manually change it to private. So short of using my pc for all invites (where I can manually set them to private each time) is there a way to do this on the Dinc?
