as of the last two days, my GMail is not connecting or syncing regularly. my inbox usually shows the no connection button and when i try to end an email it literally can take hours to send. any advice
could always try a factory reset. bet it'd solve the problem.
then there's the standard "have you changed any settings/installed any new apps, delete your apps one by one and find out if one of them is causing the problem" answer.
