dhongdhong
why gmail app does not notify email alert when phone is stand by /idle ?
Is there any workaround ?
OS: Android 4.0.4
OS: Android 4.0.4
post was not helpful. you did not understood the query.
I have already email alert notification configured in gmail app and I get email alert notification. issue is it does not work when the phone is idle/stand by (screen off).
Do you know any workaround for this ?
Apologies for my unhelpfulness but you are right, I did not understand the query. Maybe if you had explained fully that it was only an idle/stand by issue then I could have been more help.
I was trying to be helpful but your tone of reply was not very nice!![]()
Hi, I use gmail and the phone (S3 on Android 4.0.4) gives the same notification sound / vibrate as whatever the SMS is set up as, when in idle / standby. Just to clarify, your phone makes a sound when an SMS comes in but not when an email comes in? What phone are you using?
Are you using something like Juice Defender? If so, the workaround would be leaving the phone on the charger allowing notifications to arrive in real time.if the screen is off due to timeout ......no sound.
