Gmail SMTP Settings
russmd
I just switched from an original Droid to a Droid Pro. Since I use Roadrunner as my pop3 mail account, I can't use their SMTP server. I've been using Gmail's SMTP server in its place for a while without problems, but I can't seem to find the correct settings on the Droid Pro.
This is what's there:
SMTP server: smtp.gmail.com
username: name@gmail.com (on droid, I just used name and it worked)
Password: password
Advanced settings:
Port: 465
Use secure connection: checked or unchecked
Use secure password(TLS): choose from never, auto, always
Authentication: choose from none, auto, mds
Verify certificate: checked or unchecked
I've tried every combination of these settings and can't figure it out. On the Droid, it worked by using SSL, checked require sign in, and used username and password. The Pro doesn't have these options.
If anyone has this working, please specifically tell me your settings.
Thanks.
