Go Launcher EX Dock Row
JamesJoey
I'm trying to get the middle icon, which normally open the app drawer to only open the app drawer. Currently when I tap it it prompts me as to what to open, requiring me to select the app drawer icon.
When I long press and set the function to app drawer nothing changes. When I try to replace the icon, and select theme's icon, there aren't any to choose from.
Also, how can I add functions to the Dock Row(s)?
Wait a minute... While I was doing this post the icon changed and no the app drawer is opening when I tab it. So, that seems to be ok now.
I still would like to know if I can add to the Dock Row before I start deleting anything.
James
There was, but I dragged them off. I found what I did. I been so use to Launcher when I delete an icon the trash can shows up at the bottom. I was inadvertently adding other things to the icon. Problem is, even though there was only 1 item for the icon (open app drawer) it still didn't directly open the app drawer. And I can't find a way to revert it back to how it was originally.
