GO Launcher EX V3
CougarGB
I recently updated to ICS on my Samsung Galaxy SII and updated GO Launcher EX to V3.
My problem is that I went to change one of the dock icons as I have done many times and when I deleted one instead of a cross there is a blank and even a long press in the blank space does nothing!
The remaining icons just got larger :dontknow:
I would appreciate some help.
Chris
This is NOT a problem.....just create a Shortcut on your homescreen like normal.....then just drag that shortcut down into your dock.....DONE!
Also, long-pressing on any Dock icon brings up the proper menu to replace its icon....all of this works just fine for me (GO Launcher EX 3)
As Stupifier said, that is actually a feature: now you can have a custom number of dock icons, so once you delete one the rest fits themselves in the space.
To add a new one, you create a normal shortcut in any of your screens and then drag it to the dock bar.
