Go Launcher for Galaxy Ace?
Tasha129
I downloaded Go Launcher EX Notification for my Galaxy Ace. However, I cant figure out how to use it. The instructions say to go to menu, then advanced settings, but the Ace doesnt have an advanced settings. Help?
Go Launcher Notifications will only work if you are also using Go Launcher as your interface. You're still probably using the default Touchwiz that came with the phone. You need to download Go Launcher first and set that as your default launcher.
