Personally I am on a custom ROM with this phone. You should be able to look in
settings/wifi and see what the settings are.
1. If wifi is enabled, then press the wifi icon and turn it off. That will also stop the wake on LAN.
2. (Just thought of this) Go to settings. Open display. Look at the brightness. This phone is "suppose" to be smart . If the brightness is set to automatic, uncheck it. It might be detecting different light sources (shadows, tv) and turning the brightness lighter or darker depending on the source. I remembered mine did that until I unchecked that box. Don't forget to manually change the brightness though.
