Go Locker default lockscreen!!!
QCube
Hello, I tried posting this in the question section but I for some reason had insufficient access.
I've just installed Cyanogenmod 11 (Nightly Build) from my carbon ROM and I've installed Go Launcher Ex. Unfortunately, It requires a million other apps and it's making me want to throw my phone at the wall.
I am using the default lockscreen that the GoLocker comes with as I find all the other ones on the store absolutely awful looking and terribly made however, on the default launcher you swipe right and it brings up a page where you can change the settings of the theme, wallpaper, security, weather, settings and a clean option. Then underneath that part there is a load of app icons there and I have no way of changing which apps are there at all!! Sometimes I unlock my screen and there are 3 apps there, then when I go back to it afterwards, it's completely filled up!?!? They're really frustrating me!! If you take a look at the attachment I have, it's just a picture of what I'm talking about as I'm unable to post links or images.
The other thing that Is really bothering me is the icons such as the Themes, wallpaper, security, weather, settings and clean. They all serve not really much purpose apart from the weather one which I installed ANOTHER Go Launcher app and bought it which is a weather app and when I tap the weather icon, It just takes me to the stupid settings page for the weather options?!?!?
SO FRUSTRATING!! Any help would be saving me SO MUCH!
Thanks very much for the warm welcome :)
It's got nothing to do with which apps are being active unfortunately. I've yet to find a solution :/
I tried looking for a manual, but can't find anything on it...
Have you tried like long pressing those icons?
Yeah, I've held down and long pressed the buttons and they're unresponsive. Just short tap the icons and It's a shortcut to the specific app.
Most likely going to unistall all Go Launcher and all related apps and just buy Nova Launcher Prime. Much less hassle.
The apps are supposed to be the most recently used apps. As far as the other settings, you can't remove them. Just because you use go launcher, it doesn't mean you have to use go Locker or anything else they offer ie.... Go weather and the like.
I would suggest you give Nova a try as your launcher and even try widget Locker for your lock screen.
