go locker help
I just installed go locker just to change up from the stock "slide glass" or "puzzle piece" lock, it works great and love all the options and themes only (big) problem is the stock lock is still active, so basically there is two locks now is there anyway to disable the stock? I have already tried security settings and chose "none" for screen lock and it doesn't do anything.. if anyone has got any input greatly appreciated
