GO SMS color customization issue
lunameow
Currently using Handcent, but it's so slow that it's making me avoid texting altogether. I tried GO SMS, but I'm really big on customization, and that doesn't seem to be possible, yet everything I've read on here praises how customizable it is.
Here's the problem... let's say I'm using bubbles. Just as an example, the skin I use has white bubbles for incoming, green for outgoing. I want both to be white. I go to customize the color, and see that all three color sliders are already set at 255, which should be white, but it's green. And since they're already at the max 255, I can't slide them further to make it white.
I had this problem with every skin I tried. No matter what color the default for the skin was, the sliders were all at 255, making it impossible to get the color combination I want.
I haven't seen this problem mentioned in any comments or reviews. Figured I'd ask here since lots of folks seem to use it. Am I missing something?
