jzebrahockey
When I send an mms from the stock message app they send with no problems. When I try using Go SMS Pro I can't send them at all. They just sit there and try to send. If I go into the stock one and edit the message trying to send and try sending it again it sends. Has anyone else had this issue or know how to fix this. I do like Go SMS but if I can't send mms then what's the point. Thank you for your help.
