Help GO SMS PRO help
bufflsu
when ever i send my friend a text it shows up my go id or something on his phone. anyone know how i can stop this from happening, and get it to show up like normal. his info shows up normal on my phone. we both have the same phone
EXACTLY WHAT does it show on his phone, and where does it show it?
you are not being detailed enough with your question.
sorta like, if someone says you can do this or something and it will fix it.
In the top right hand corner of the screen make sure the "Go" icon is not glowing orange. If it is, just tap it to make it stop glowing and that should allow you to send a regular text.
Go into settings and change the RUNNING mode from Pro to Normal and you wont have the Go Chat option anymore. might be much simpler.
