Go sms question
wtam1100
I download Go sms yesterday to replace handcent. I like it so far but here is my only problem with it and I need someone to tell me if I am missing something. Now after I install go sms I no longer have a enter buton. It has been replaced by a smiley button. Is there a setting that I can change so I can have a enter button instead. I tried a keyboard that was like that once and it had a opt for either a enter button or a smiley button. If anyone can offer any advise I would appreciate the help. I like this sms app but not having a enter key is a deal breaker for me.
I don't think that's an issue with Go SMS, but with the android keyboard. You can change to a different keyboard if you have one installed by long-pressing in the text field and choosing "input method".
You are kind of correct. When I go back to the stock keyboard I get the enter key back. If I try swype, 2.3 keyboard, swift key etc I lose the enter key. How is this not a issue with Go sms? When I use handcent or chomp I dont have this issue with any of the keyboards I use. It's not like I'm changing the setting for my keyboard to change the enter key to a smiley button.
Hey, go into GOSMS homescreen, press menu-> settings. Go into Send settings, and scroll down to the option "Action Key Type", change that to "enter"!
And there you have it :)
