Gogle Earth Location Dot
I'm not sure if this is the right forum for this, but I do not like the way that the blue location dot uncertainty circle blocks a complete view of the map in Google Earth Mobile.
I've tried turning off the WiFi location setting, but it doesn't get rid of the dot or circle. I've read that you can press the "0" button to turn it off, but I've got a Vibrant, not a Blackberry.
This has completely ruined both Google Earth and Google Maps for me. I don't mind it going to my location, and would even give up a tiny bit of view if it was only a VERY small blue dot, but the uncertainty circle ruins my view by blocking part of the map.
I work in the property management business and need to see all of a property, not just the 50 feet where I might be standing.
Any help for this? Thank you!
Welcome to the Android Forums!
Try checking in the Android Applications forum or Android Lounge. Someone in one of these sub-forums may be able to suggest a fix for you...
